Version: 028-rc10
Pantavisor Configuration
!!! Note The configuration syntax is common for all levels, but not all levels support the same keys. Our reference contains the list of keys and the allowed levels for each one.
For setups where we want to modify the configuration based on device updates, we offer the possibility to attach a configuration file to a revision.
Its location inside the revision will be defined by the configuration values of the keys PV_OEM_NAME and PV_POLICY from pantavisor.config, environment variables or policies levels.
!!! Warning This method is DEPRECATED but still supported for backwards compatibility reasons. It is recommended to use env variables instead.
!!! Note If the user metadata volume is assigned to a permanent volume, as it is by default, these changes will persist over device reboots.
User metadata can be used to override any of the previously presented configuration mechanisms.
!!! Note It is important to notice that these changes will not persist after a device reboot in any case.
