Version: 028-rc10
Pantacor Hub is our remote device state management system.
Pantavisor includes a build-in Pantacor Hub client which is enabled by default. To begin remote control and monitoring of devices with Pantacor Hub, it is necessary to create an account and claim the device to it. From that moment on, the device will be attached to that account and will try to keep the connection with Pantacor Hub opened, except if a local revision is installed. In that case, the device will turn to local control until a go remote command is issued. This behavior can be avoided with the remote always configuration.
!!! Note All states are independent from the Pantavisor state machine, but all their associated processes are run from its WAIT state.
!!! Note The client state can be consulted at any moment via device metadata.
  • register: device is trying to register as a non-claimed device in the cloud. This credentials will be stored after reboot.
  • claim: device is registered and is waiting to be claimed.
  • sync: device has been claimed and will try to upload the objects and state JSON to the cloud.
  • login: device is using its credentials to start a session with Hub.
  • wait hub: device is waiting for Hub to reply. We also use this to decide whether the device is claimed or not.
