Version: 030-rc1
Init Mode
Pantavisor offers several configurable init modes for convenience: embedded, standalone and appengine.
Embedded Mode​
This is the way Pantavisor was meant to be run. In this case, the bootloader will directly start up Pantavisor, which will run alongside a minimal rootfs with all its dependencies.
Standalone Mode​
This mode was created for debugging Pantavisor. It works the same way as embedded, with the bootloader starting Pantavisor up. The difference is Pantavisor will not launch any container or perform any of its regular operations. To do so, Pantavisor has to be manually run from console inside of the device.
AppEngine mode​
AppEngine mode is meant for prototyping on already setup devices running any Linux distro. In this case, Pantavisor will run as a daemon that can be started from your init system or directly from console.
Containerised appengine​
The same mode also runs with Pantavisor as PID 1 inside a container, which is how the runtime is developed and tested off-hardware. It is the same pantavisor binary with the same revisions, containers, updates and pv-ctrl API, while the board-specific parts (bootloader, watchdog, secure boot, hardware reboots) are stubbed or simulated.
In this regard, the entrypoint for this container is pv-appengine, a looped script in charge of simulating the bootloader, reboot and poweoff behaviors. Furthermore, on first boot, the entrypoint seeds storage from the skeleton, deploys an initial revision with pvtx from /usr/lib/pantavisor/pvtx.d/ plus anything present in /usr/lib/pantavisor/pvtx.extra.d/, and writes the initial boot state to storage/boot/uboot.txt.
Pantavisor reads PV_* config keys straight from the environment, so any of them can be overridden per appengine container without editing a config file, which offers the ability to test different setups without having to rebuild the binaries.
Some container-specific behaviours worth knowing:
  • Loop devices: There is no udev, so /dev/loop0..1023 are pre-created. Loop devices are host-global, so concurrent appengines each need their own PV_LOOP_INDEX_BASE 64 device range reserved. To avoid conflicts with leftover loop devices, the entrypoint reaps stale devices in its own 64-device band, detaching only those whose backing file reads (deleted).
  • Log location: Logs live under the storage mount at <storage>/logs/0/, not /run/pantavisor/pv/logs/0/ as on a device so they can be inspected from host. PV_LOG_SERVER_OUTPUTS=filetree,stdout_direct additionally streams the internal log to stdout, unbuffered, as each event happens. See logserver-sockets.md.
  • Named initial revisions: Pantavisor only auto-commits the revision it boots into when that revision is named 0. When PV_APPENGINE_INITIAL_REV names a different revision, pv-appengine writes the .pv/done and .pv/progress markers the factory path would have written. This is what lets a caller boot straight into a prepared revision with no install and no commit reboot.
