Version: 031-rc7
Pantacor Hub is our remote device state management system. It's optional — Pantavisor updates fully standalone over the local network without it. Pantahub is also open source and self-hostable; see Project, licensing, and governance for the license split and what's commercial vs. open.
Pantavisor includes a build-in Pantacor Hub client which is enabled by default (PV_CONTROL_REMOTE, default 1). To begin remote control and monitoring of devices with Pantacor Hub, it is necessary to create an account and claim the device to it. From that moment on, the device will be attached to that account and will try to keep the connection with Pantacor Hub opened, except if a local revision is installed. In that case, the device will turn to local control until a go remote command is issued:
pvcontrol cmd go-remote
This behavior can be avoided with the remote always configuration (PV_CONTROL_REMOTE_ALWAYS, default 0).
The owner of a claimed device can also lock its identity in Pantacor Hub and request a reset in order to renew device credentials. It is only supported when remote always is enabled, as it automatically runs a temporary local revision while the rest of the revisions are cleaned up from disk to start fresh. Then, it drops its old credentials, registers again as a new device linked to the old one and is left again ready for claiming.
All states are independent from the Pantavisor state machine, but all their associated processes are run from its WAIT state.
The client state can be consulted at any moment via device metadata.
  • register: device has not been claimed yet, so it asks the Hub for pre-claiming temporary ones. Those are kept on disk until the device is claimed.
  • login: device is using its credentials to start a session with Hub. This is where Pantavisor checks if an identity reset has been issued from Hub.
  • reset confirm: the new identity has been claimed and the device is confirming to Hub that an identity reset has been successfully concluded. If Hub reports the new identity as unclaimed, the reset is dropped instead.
  • claim: device is registered and waiting to be claimed. Claiming only progresses while the running revision is DONE.
  • wait hub: device is asking Hub whether its running revision is already in its trail, which means Hub comms work and the device is claimed.
  • prep sync: objects that checksum validation did not cover are hashed. The ones that no longer match their ID, such as writable images, are left out. The device then asks Hub for an upload URL for each object.
  • sync objects: device is uploading the artifacts that are not yet present in Hub.
  • sync state: device is posting its state JSON to Hub, which becomes the first step of its trail.
Only object hashes that changed are downloaded — for a sense of scale, see meta-pantavisor's firmware-size guide for an illustrative example (not a measured benchmark).
  • Configuration — every PH_* key, plus PV_CONTROL_REMOTE and PV_CONTROL_REMOTE_ALWAYS
  • Metadata — what the device reports up and what it reads back down
  • State Format — the revision format the trail is made of
