Version: 031
Configuration Levels
The configuration syntax is common for all levels, but not all levels support the same keys. Our reference contains the list of keys and the allowed levels for each one.
Keys use the unified PV_*/PH_* env-var-style syntax; the older dotted syntax is legacy and frozen, so any key added since (e.g. PV_POWER_*) only exists in this form.
For setups where we want to modify the configuration based on device updates, we offer the possibility to attach a configuration file to a revision. This way, the configuration values travel with the revision like any other artifact: they can be changed with a regular update, are covered by the same rollback guarantees, and do not require rebuilding the Pantavisor image.
How it works​
Every time a revision is started (after boot up or a device update), Pantavisor searches inside the revision for a configuration file at:
<PV_OEM_NAME>/<PV_POLICY>.config
The two keys that define this location are set at the pantavisor.config, environment variables or policies levels:
KeyDefaultEffect on the OEM level
PV_OEM_NAMEemptyName of the directory that contains the file. If not set, the OEM level is disabled and no file is loaded
PV_POLICYemptyName of the file. If not set, the file name falls back to default.config
For example, with PV_OEM_NAME=myoem and PV_POLICY unset, Pantavisor will load myoem/default.config from the revision. With PV_POLICY=production, it will load myoem/production.config instead. This means a single revision can ship one configuration file per policy, and each device will pick the one matching its installed policy.
If PV_OEM_NAME is set but the revision does not contain the file, an informative message is printed in the logs and startup continues normally.
The file uses the same key=value syntax as pantavisor.config. Its values are applied at the OEM level, so they overwrite pantavisor.config, pantahub.config and policies, but can still be overwritten by cmdline, environment variables, user metadata and commands. Only the keys allowed at the OEM level will be accepted, while the rest will be ignored with a warning in the logs. Our reference contains the list of keys that can be set at this level.
How to set it up​
First, set the OEM name in one of its allowed levels. The typical choice is pantavisor.config at build time:
PV_OEM_NAME=myoem
Then, attach the configuration file to the revision from a pvr checkout of your device:
mkdir myoem
cat > myoem/default.config << EOF
PH_METADATA_DEVMETA_INTERVAL=30
PH_METADATA_USRMETA_INTERVAL=30
EOF
pvr add .
pvr commit
pvr post
After the device runs the new revision, the overridden values can be verified with pvcontrol, which reports the level each key was last modified at:
$ pvcontrol conf ls
"key": "PH_METADATA_USRMETA_INTERVAL",
"value": "30",
"modified": "oem config"
If state signature validation is enabled, the OEM configuration directory, like the BSP one, can only be secured by a certificate that is validated against the default root certificate. Signatures whose certificate subject CN matches PV_OEM_NAME are validated against the OEM root certificate instead, and cannot include any artifact from those two directories. See the certificate chain of trust for more information.
warning
This method is DEPRECATED but still supported for backwards compatibility reasons. It is recommended to use env variables instead.
If the user metadata volume is assigned to a permanent volume, as it is by default, these changes will persist over device reboots.
User metadata overrides all the previously presented configuration mechanisms, but only for the keys allowed at the user metadata level, while the rest will be ignored with a warning in the logs. Our reference contains the list of keys that can be set at this level.
It is important to notice that these changes will not persist after a device reboot in any case.
  • Configuration — every key, its accepted values, its default, and the levels it may be set at
  • State Format — where the OEM config file sits in a revision
